SETidriver question and S@H question
poopaskoopa
do i need to use i386-winnt 2.4 to use setidriver? i run both win98 and 2000 on my machine. i currently run s@h only on win98. is it possible to work on the same wu when i'm going back and forth between win98 and 2000? thanx.
Yes, you need the i386-winnt client, and yes you can run it on either OS. At least if there's some way to access one filesystem from both sides (I don't know much about how dual-boot WinNT/2K/9x systems are set up.)
Well, I think if they're both using FAT you should be able to use the same .exe in both OSes. But if you're running FAT for Win98 and NTFS for Win2K, you might not be able to use the same WU.
