Seti times for my Duron sound right?
Ben98SentraSE
449
I have a Duron 700@933 running on an Abit KT7A at 133/133 CAS2. After 15 WU's I average 7 hours 11 minutes with Win2k server and the CLI. I use this computer 9-10 hours a day but nothing CPU intensive. Does that sound right?
I have a GlobalWIN FOP38 (loud but the Unisys mainframe behind me drowns it out :)) fan and the temp hovers 105-107 degrees F, but if it push the FSB up a mere 2MHz the thing won't boot. I run her at 1.80V. Any help with that either? Haven't tried the L1 bridges yet to unlock the multiplier so I'll probably try that today... although I would be happy if 933MHz was the max :)
Assimilator1
24,165
524
Ben 98
Are you sure none of those progs are cpu intensive? ,have you checked them with a Task manager?
Nice machine you have BTW :)
lane42
5,721
624
Well, Thats alot faster then my duron 600@977. Gotta figure out why its only doing 9.5 hour wu's :(
Durons are supposed to be faster then cel's but ive seen 850 celerons that do faster wu times.
Polo
4,185
My Duron 900 (9*100) averages 8h36min on Win98SE with both SETI 3.03 CLI and RC5 running. When checking with ATM, DNETC.EXE takes 5 to 6% of the CPU usage. Without running RC5, I think could gain 30min per WU --> 8h per WU.
So your average time seems OK. :)
Insane3D
19,446
So far, I am getting about 4.5hrs per work unit, so for that speed it sounds about right. I have a faster CPU but the same motherboard, so it's a good comparison. Also, your Duron 700 should go over 1ghz easily without much trouble...most of the 600 hit 1-1.1ghz. How do you like the KT7A? :)
Fardringle
9,200
765
Ben, if you're getting 933Mhz out of that system without even touching the multiplier, you may very well have a system to drool over! Unlock those bridges and crank that baby up!! ;) You should EASILY get 1Ghz+!!
lane42
5,721
624
Hay Assim1,
FSB is 115 and for memory iam only using 64mb pc133 cas3.
Sisoft sandra reports memory Bus Speed as 109mhz.
This is a seti only Box with nothing else running.
lane42
5,721
624
dzr, no, ill see what happens.
Dasm, set from 3 to 2 and it froze up. had to set back to 3.
Assimilator1
24,165
524
Lane42
Bens FSB is 133MHz (he has the KT133A chipset) ,so is his memory bus ,also he is running @ CAS2 at those settings ,that's why his times are much faster than yours.
BTW you'll probably find that if you reduce your FSB (& thus your memory bus too)a little to the point that your RAM will run at CAS2 then your times should improve.
Inccidently I am currently running PC133 CL3 at 126MHz CAS2 ,but that will vary with the RAM.Though I am surprised your PC133 CL3 won't do CAS2 at 109MHz.
Keep us posted :)
lane42
5,721
624
Yes, i think its time to attack the Bios.
Hmmm, Any good sites for the abit KT-7 mobo settings.
