Hi guys
I turn to you all again for advice! The questions I ask here are probably easily solved by a search, and I have done some basic research, but I find that there is nothing better than the opinions of people that have done this sort of thing before, so without further ado:
What I plan is not necessarily going to be a crack-rack in the normal term. I propose to setup a small herd of PCs (some with, some without cases - depending upon wether I have them or not at the moment) as I have at least 2 PCs built that I am not using at the moment, and perhaps another 2 or more in old-ish parts and it seems a waste to leave them not running. Just FYI, most of these will be used only for running SETI, none of these are going to be 'used' by a human. Anyway lets get to the nitty-gritty:
I do not have Windows licences to run these machines with - I would like to run Linux on these machines. I have almost no Linux knowledge whatsoever. The reason for going with Linux is that it is free in the sence that it doesnt cost more to add another machine - and there is a potential (the needs are fulfilled - space for the machines etc) to run quite a number of PCs.
I would like to setup one 'control' PC running a SETI Queue aswell as the SETI CLI. Is there a version of SETI Queue for Linux, or would I have to make this machine Windows (one Win machine is not a problem, as I have one spare licence at least). I have my main PC upstairs, and of course it would be possible to run a Q on that, however I cannot guarantee the uptime of that machine as I tend to take it apart rather frequently, and I also have to sleep in the same room... 😱
So I need some information along the lines of:
A general intro to Linux - this I have found
Running a DC project with Linux - What do I need? Distro, SETI program... some sort of GUI like X Windows to run the Win version of the CLI?? IS there a Linux port of the SETI CLI?
A recommended distribution - wether I buy this or download (have broadband at home) is not an issue, I am willing to spend a little on a distro (then again, if I spend ££ on a distro, there are fewer funds to buy parts with...)
Info on what spec the components such as HD and RAM need to be on each node - For the PCs that are just running SETI: Is 1 GB enough HD space for distro + program? What is the minimum HD space you can get away with? At what point does adding RAM fail to see an improvement in WU times?
What is the process for getting a node working? - Assemble PC (CPU, mobo, RAM, NIC etc), Add cards for install (Video, CD etc), Install distro/program, Run, remove excess components (Video, CD etc), Leave running - is that right?
A lot of these questions can be answered at a later date I know, I would just like to know what I am getting myself into. The reason I ask here is that I believe there to be quite a few veterans of Linux and DC in general around...
Many thanks guys, I couldnt do this without you!
Feel free to spawn opinions etc - this is going to be fun! 🙂
Oh, by the way - those of you who are part of other DC projects, have no fear. If a machine is poor at running SETI I have no qualms about running other projects instead 🙂
Migroo
Migroo
