seti queue help
Unforgiven
1,827
im running a private queue for the members of my small seti group and am running into an issue that i was wondering if anyone could assist me with troubleshooting. i have 2 users on 56k dialup connections and the server uploads to them are horribly slow and the dos window seems to just sit at 240k downloaded and does nothing after that. if you close the window and try to transmit again it just seems to do the same thing and hangs for awhile then tries to throughput more of the unit but it never completes. the users are using the 3.03 cli and 3.08 cli respectively. if anyone can help or tell me if i have a setting wrong in my server setup it would be greatly appreciated.
thank you
Smoke
Distributed Computing Elite Member
Jan 3, 2001
12,650
207
That sounds more like an internet connection problem more than anything else. I know of no setting that would cause such a behavior.
Can the CLIENTs go directly to Berkeley for their WUs without difficulty?
Have them try that and see if the problem is on their end.
TofBnT
1,838
Some of my work computers do this. Others work fine, if I leave them alone, they eventually finish.
Unforgiven
1,827
they can connect directly to the berkeley server with no issues. uploading a finished unit isnt a problem at all (to my queue), just the download. i guess ill just tell them to have it sit there and see how long it really takes for the entire thing to download. ill report back with what i find out. thanks for the posts!
Freewolf
9,673
Have you thought about joining Anandtech? Your group could join as a miniteam like the miniteam I'm a member of The Rebel Alliance.
Unforgiven
1,827
yeah just a small bunch of crunchers so no website. actually i have considered joining team anandtech but like assimilator said, im founder and i cant bail on my group. :) all i know is that i hope SETI I keeps on rolling for a few more months because i would like to get as many of my teammates over 1000 units, get myself to the top 1% of crunchers and in the process find et. ok the last part wont happen but i love crunching and im a stats geek. btw, thank you to all of you who have even bothered to post at all, anandtech is the best tech forums out there and i love posting here! thanks to you all!
Assimilator1
24,189
529
So where/how does your group chat to each other?
Btw you could always start a new account for TA;)
Smoke
Jan 3, 2001
12,650
207
Here's an idea how you and all of your mates can Join TeAm AnandTech and still be part of the same group.
Have them Join TeAm AnandTech and change their Seti Names as follows:
BuN-Knee Express ()() - Unforgiven
BuN-Knee Express ()() - PurpleCfh
BuN-Knee Express ()() - Bandsaw![TG]
BuN-Knee Express ()() - WolfyBix
BuN-Knee Express ()() - [bAd]Junk
BuN-Knee Express ()() - BuddhaMan
BuN-Knee Express ()() - abso
BuN-Knee Express ()() - 7thSign[tg]
BuN-Knee Express ()() - Ronin
BuN-Knee Express ()() - Taya
BuN-Knee Express ()() - JarrettH
BuN-Knee Express ()() - prr727
BuN-Knee Express ()() - MART is GAY
BuN-Knee Express ()() - Dial
BuN-Knee Express ()() - Maverick[TG]
BuN-Knee Express ()() - ArtisShmartis
BuN-Knee Express ()() - BuN-Knee
BuN-Knee Express ()() - Shanks_
BuN-Knee Express ()() - Teh Bluehen
BuN-Knee Express ()() - Pallidrone
BuN-Knee Express ()() - Beotch
BuN-Knee Express ()() - HydrA
BuN-Knee Express ()() - MAX
BuN-Knee Express ()() - FADES
BuN-Knee Express ()() - KegRun
BuN-Knee Express ()() - Jazwana
BuN-Knee Express ()() - Chaos
BuN-Knee Express ()() - guido
BuN-Knee Express ()() - Jayman
You all could be a team within a team. :D
Unforgiven
1,827
this seemed to work. i just let them sit there for a bit and it went through. i dont know why it hangs (sometimes it does it on my dsl and t1 connections as well). thanx for the tip!
