- Jan 5, 2003
- 2,123
- 2
- 81
picture of the problem<<<I accedently had the compression set too high
Nearly every morning when I wake up I receive this message. While this message is displayed it just sits there doing nothing (always at around 3% complete) until I press the "do not send" button when it then continues like nothing happened. Checking my setiQueue log, this machines last result was at 12:53AM, it then processed about 3% of the next WU and that message came up therefore causing it to do nothing. So it just sat there until I just checked on it at about 6:50AM having accomplished nothing.
During the day I check its progress with SetiWatch several times per hour, maybe the lack of activity during the night causes it to do this? This machine is overclocked, it has proven itself stable in the past but I guess I shouldn?t rule it out. If it just came up with the message it wouldn?t bother me, but since it stops the progress of the WU it is a bit angering. I lost 6 hours (3 WUs) last night. However the night before It stopped several minuets before I woke up.
I will run scandisk and defrag on it and see if that helps.
