SETI@home daily stats for 14.01.2007.
Rattledagger
2,994
19
#____Total Work Done____Todays WD_____AWD________overtake_______Team-name
01______187.837.465______346.943______353.186______impossible______SETI.Germany
02______159.188.022______802.539______758.288______impossible______SETI.USA
03_______90.092.463_______35.240_______54.971______impossible______BroadbandReports.com Team Starfire
04_______70.334.543_______74.104_______89.232______impossible______Czech National Team
05_______70.044.933______136.154______138.747______impossible______L'Alliance Francophone
06_______65.579.550______120.799______140.436______impossible______BOINC Synergy
07_______58.700.835_______79.829_______72.377______impossible______SETI@Netherlands
08_______43.940.080______-13.111_______-8.836______4.973 days______OcUK - Overclockers UK
09_______34.045.404______-16.191_______-5.004______6.804 days______BOINC.Italy
10_______31.476.145_______86.282_______96.117______impossible______The Knights Who Say Ni!
11_______26.214.088_______31.151_______39.122______impossible______Overclockers.com
12_______21.001.045_______47.717_______69.733______impossible______Team Art Bell
13_______20.230.090_______51.095_______44.228______impossible______Team 2ch
14_______16.617.861_______38.469_______43.249______impossible______The Planetary Society
15_______13.331.718_______31.747_______36.042______impossible______Ars Technica
16________3.440.774______-24.909______-25.207________137 days______Universe Examiners
17________2.389.181_______73.728_______75.518______impossible______Team MacNN
18_______41.544.402_______79.380_______75.768______notanoption_____TeAm AnandTech
19_______-1.640.477______-24.280______-23.790______impossible______Phoenix Rising
20_______-5.958.903______-57.221______-51.331______impossible______Planet 3DNow!
21_______-8.153.943______-44.662______-38.716______impossible______PC Perspective Killer Frogs
22_______-8.460.834______-22.028______-17.376______impossible______Hewlett-Packard
23_______-8.578.255______-22.319______-11.001______impossible______Amateur Radio Operators
24_______-8.597.549________7.202_______23.651________364 days______SETI@Taiwan
25_______-8.710.080______-42.556______-37.517______impossible______2CPU.com
26______-10.909.239______-18.841_______-8.674______impossible______Canada
27______-12.653.693______-61.388______-56.238______impossible______Picard
28______-12.709.515______-20.024______-17.354______impossible______SETI@China
29______-13.936.041______-36.524______-33.281______impossible______Portugal@Home
30______-14.076.042______-33.763______-36.743______impossible______BOINC@Denmark
31______-14.165.039______-22.941______-20.190______impossible______Team NIPPON
32______-14.745.761______-58.393______-51.297______impossible______LittleWhiteDog
33______-15.132.250________3.862________3.234______4.679 days______Team MacAddict
34______-15.453.999______-13.284______-11.445______impossible______Dutch Power Cows
35______-15.560.308______-29.925______-23.064______impossible______BOINC SETI@home RUSSIA
36______-18.200.977______-12.463_______-8.695______impossible______Hungary
37______-18.916.205______-45.639______-45.069______impossible______Team EDGE
38______-19.885.070_______56.221_______67.652________294 days______Team Starfire World BOINC
39______-20.144.454______-33.971______-30.386______impossible______SETI@klamm.de
40______-21.135.707______-31.274______-28.315______impossible______HispaSeti&BOINC
41______-21.562.449______-24.646______-17.384______impossible______BOINC@AUSTRALIA
42______-21.606.892______-22.067______-15.922______impossible______UK BOINC Team
43______-21.727.678______-41.583______-36.454______impossible______SETI Sverige [Sweden]
44______-22.118.230______-23.035______-25.048______impossible______U.S.Air Force
45______-22.778.036______-55.717______-47.921______impossible______The Final Front Ear
46______-23.219.417______-37.817______-30.945______impossible______SETI.hr
47______-23.220.236______-23.922______-21.316______impossible______US NAVY
48______-23.367.139______-42.640______-42.539______impossible______World Wide S.E.T.I.
49______-23.606.796______-44.937______-41.975______impossible______BOINC UK
Appart for Anandtech's stats, it shows how much more/less than Anandtech.
Also shows based on Average Work Done how many days for Anandtech to overtake the team, or be overtaken by a team behind...
Assimilator1
24,179
528
Starfire seems to be holding steady atm.....
Thx RD :)
Btw is it possible to grab a 'typical' WU & then keep it to use it as a benchmark? same as TLC did for S@H1
Rattledagger
2,994
19
Well, the "easy" way is to just save the whole BOINC-directory, and just re-crunch whatever wu you've saved. Just make sure you're disabled net-connection. ;)
It's also another way to run seti stand-alone, but don't remember the particulars of this to get the logging of cpu-time to work...
Anyway, just like in the old TLC-wu, majority of wu under Seti_enhanced has angle-range around 0.42.
But, not sure that will happens when the multi-beam "soon" takes-over, the beam-width is reportedly smaller, so likely the angle-range will also be smaller...
