SETI: Help - can't run on two machines!!
Moltres
Hey TeAm Seti,
I used the setup instructions from Smokeball to get SETI running on one machine. I updated my account info. I tried to use the same instructions on a second machine except selecting '2 - already have an account' in the DOS window. It keeps saying there is no such account. I try '1 - create an account' but it just prompts for 1 or 2 again. Do I have to wait awhile to add another machine to this account or am I doing something wrong?
Moltres
You shouldn't have to wait.
Try checking that the email is exactly the same.
What is the name it is under?
Sounds like you're doing it right.
After you installed the client on the second machine, try to get it to download a work unit, enter #2 , put in your e-mail address(same as on the 1st)and you should have a go. Are you using any kind of cache client? i.e. SETI Driver or anything else?
You could try copying a work unit over from the first machine to the second machine to get it started.
