seti driver problems
rival
um, when i run it, it 'eats' my seti client cli .exe file, where does it go? is it in the wrong dir?
Hi.
When you are setting it up, do not click on the "New Client". This seems to delete it!
When you run SetiDriver for the first time, it should ask you for the CLI. Point it to the CLI, then set your settings and then click on Save Config
Hope this helps, if not then post back here and someone else will help!
Confused
Or just put a copy of the SETI CLI in the same directory as SETI driver, and it will find it automatically without even asking you.
Actually, thinking about it, he's right!
It's been so long since i've set up SetiDriver!
