Hey all,
I just recently finished building my own computer, and am having some serious issues with the CPU temperature. The specs of the computer are below (I will make a system rig as soon as I remember my password
Athlon T-Bird 1.33 @ 1.4 (1.85 V, 10*133 - nothing too bad)
MSI K7 Master (MS-6341)
GeForce 2 Pro 64 meg
SB Platinum 5.1
Antec SX830
Swiftech 370-0A with Delta Fan
256 DDR Ram
Now for the issues - when I go into the Bios and check the temperature, I am seeing a System Temp of 26 C, and a CPU Temp of 75 C. Of course, that is insanely high - I might get that if I had no cooling on the thing at all. I have the Swiftech on the chip however, and two fans on the back and one in the front, which, although loud, should be more than enough cooling on the chip, although I am still seeing this temperature. My ambient temperature is somewhat high - it is in a loft that in the afternoon may reach the high 70's for a temperature...but that is still much cooler than the chip temperature, so the heat exchange should still be more than adequate.
I installed Motherboard Monitor (MBM) and am getting 3 temps returned - Temp1 = 26 C, Temp2 = 75 C, Temp3 = 40 C. I am seeing a discrepancy however with what temp corresponds to what. I went to the MBM website to check my motherboard, and it is listing, under # MS 6341, that the CPU temp, corresponding to Via 686A, is Temp3. However, in MBM I have the sensor listed as Via 686B, and all of the mobo's on the website that have 686B on them show Temp2 is the CPU temp, which is bad. Plus, there is the issue that the bios is returning 75 C for the CPU temp as well. I couldn't locate any documentation on what temp sensors correspond to what on Via's or AMD's websites...
And basically, that is where I am at. That temperature is extremely high, and hopefully I am not frying my chip - I have seen no instability issues whatsoever in Win2k though.
Any suggestions or advice about what could be happening/what I could try/what could lead me down the path of enlightenment would be much appreciated!
Thanks in advance!
SB Platinum 5.1
Antec SX830
256 DDR Ram
Thanks in advance!
