Originally posted by: apoppin
Originally posted by: akshayt
What advice did I ignore?
1. WHAT is your PS . . . it HAS to be 'beefy'.
2. dump the O/C . . . run it at STOCK speeds and default. 😛
. . . and 3. "reinstall your OS" usually works
[if everything else fails]:Q
finally . . . . 4. 'forget' demos and use games to test your rig. 😉
you got 1 outta 4
back early from work and less cranky than before i left . . .
You PS may not be enough for your O'cd system
the fact that your had improvement when your system went to default seems to indicate there is an error in setup - double check your BIOS and perhaps Reinstall XP . . . perhaps there was an error or you messed up a MB driver.
Game DEMOS are NOT generally reliable for testing Rigs - and may be buggy . . . only use fully PATCHED games.
Finally. your CPU is not DC [is it?] . . . SS2 still has problems with Dual-core
FINALLY what are your 1) Case, 2) CPU and 3) XTX temps? Many cases are designed to cool better CLOSED.
