Serious Problem!
bobbytron
20
ok something i download off of morpheus had a false name/discription so when i got it i beleave it totaly screwed my computer..it gets really slow and my dsl icon is in constant green with the bytes sending and receiving like crazy..i have tried deleting this file but it says
"Cannot delete ---------------:Access is denied. Source file may be in use."
i really need to fix what ever this problem s i just bought this computer(its only a few weeks old)
Theslowone
1,779
it sounds like a virus from a .vbs(visual basic script) or what ever that extension is, get norton or mcafee and update to the newest definitions. Norton is free for the trial version, and that should be all you need.
here is the link, it may have got you to bad and you might need to format/re-install. Watch out with mp3s and all because if it is the virus I think it is it adds itself to almost every file extension.
The source file in use sounds like a. either someone is trying to dl it, or b. it is stopping you from doing it. If someone is trying to download that file you need to close all your file transfer programs and then try to delete it.
