Lately my system has been freezing up--then resuming.
Example: typing in word while listening to winamp, the whole system locks, the sound buzzes then resumes just fine. This is intermittant. It also happens during games.
An odd thing started happening yesterday; it was as if my windows key was permanantly stuck down. Hitting the f key would bring up a find window, r would bring up run.
This appeared to be some sort of accessability feature that I never turned on. While trying to disable this, on a reboot my system came up with NTLDR not found -- Press ctrl+alt+del to restart.
Couldn't get into windows AT ALL. No disks in the drive. No way to get on the web to troubleshoot.
I bit the bullet and reformatted my system partition, clean install. Now I'm noticing these wierd processes in task manager: wmiprvsrv.exe, wuauclt.exe, and another wu file. Googling these show a possible trojan, but I don't have any of the files it suggests in the registry. End tasking them causes a different one to show. I found instances of them in /windows/system32/i386 and /windows/system32/wbem. There are also prefetch files for these which I've deleted.
Deleting these and rebooting has had no effect.
I'm totally stumped. Can't find anything out on the web. I have run windows update and fully patched. I installed sp1 instead of two. I've also run a full virus scan, in safe mode as well with no results. I use my NAT firewall with my belkin router.
Help!!!!
EDIT: I deleted wuauclt.exe out of /system32/wbem. Win file prot came up and says 'file required for win to run properly have been replaced by unrecognized ver. to maintain system stability win must restore orig ver of these files' Insert sp1 cd now. AUGH
Help!!!!
