Serious MSI kt3-ultra problems!!!
I have a year old kt3 ultra and after a few changes to the "advanced chipset/dram settings" having to do with CAS latency aso with some new memory. Anyway after changing the settings the computer wouldn't start, the "D-bracket" posted 4 red leds - According to the mobo manual that indicates that the CPU is corrupt or badly attached.
WTF!!! I didn't touche the CPU, I've reinstalled it and reapplied AS3 removed all other components and installed again, cleared CMOS, removed and attached battery, tried different memory...
PLEAS ANSWER ME!!
PLEAS ANSWER ME!!
Maybe you accidently overclocked it?
Try another cpu to see if that is the issue.
When you pull the battery, unplug the powercord too, and let it sit for about an hour.
When all else fails, try sending an email to MSI tech support.
