Hi All!
I am again writing in Notepad as the last 4 posts I attempeted to make were interrupted by BSD's.
As of right now, I reboot, randomly, about 4 times per hour, from ANYWHERE in Windows. This includes the desktop itself,
immidiately after a prior reboot. I woke up, turned my system on, went to the forums, began reading new posts. 2 mins
later, Blue Screen. The last 3-4 BSD's have been slightly different. n4_disp.drv or something very similar to that (My
Display Driver) would be cited as reason for BSD (and a few win2k.sys ones) but after the BSD upon entry to Windows I would
get error reports stating that Windows thinks my video card is dying, because it (Vid Card) was unable to complete a drawing
operation. I will repeat, these latest ones, have been largely in the desktop, or IE or WE.
Okay, last post I didn't reply to was Aelus. Thank you for your suggestion about ACPI, that is actually very helpful.
Next, Bozo Galora. I was writing a reply last night which was destroyed on like the 3rd page, sorry for the delay.
<next 10 lines being re-written, just rebooted from Notepad!!!>
I am aware of the AGP miniport issue. I have had an AMD miniport driver installed sinse day 1. It is an AGP card, it does
say so on the website, althought the web design is so awful I don't blame you not noticing.
Your ideas about XP and SB Live! being crap are non-issues, other OS's have been tried and failed, and failures persist with
or without the sound card in the system. Sorry, there you got ahead of yourself...
DirectX are 8.1b as of several weeks ago. Either very latest one one stepping below the very latest available as of today.
As for the AGP 1x 2x 4x issue. My card supposedly supports 4x. I am not sure what it RUNS because it's automatically
decided somewhere for me, but I will try setting it to 1x. I am pretty sure that has been tried before tho. The coolbits
ideas, I don't know what that is all about. What does coolbits do that can help me??
The textures edit comment, do you mean "memory allocated for textures"?
BingBongWongFooey: Given my system config, you think a 300W PSU is too weak? Anyways, I need a replacement PSU, I'll need a
few days to get one and test it anyways. Lots of people are telling me it's the PSU. Lots are blaming HDD or Video also.
Aelus, yes I do crash in Windows. Some of the background programs that are always or usually running for the last 5 months,
excluding tests where I specifically removed them:
Norton AV 7.5 Corporate
AIM
WinAmp Agent
Direct CD Agent
And a few others that aren't running now that I cant recall.
Bozo: What is this video voltage issue you are talking about? Never heard of it.
Bozo: Why do I use my Vid card? Cuz it's fast, and cuz I have no money for new parts after the August upgrade and all the
subsequent cr*p. If I do need a new Vid Card, I been oggling the Hercules 4500 Kyro II based card. Any comments on that, is
that a decent card for the money?
Veryape: I do have a 300W. As above, if/when I can get a replacement to test with, I will do it.
I must quickly run to breakfast before I am left hungry for the whole day. And lastly:
HAPPY BIRTHDAY TO ME!
Thanks all!
Ritaly.
