Serious Hardware Trouble
jteow
16
Specifications:
Mobo: MSI K8N Neo2 Platinum
Processor: AMD Athlon 64 3000+
PSU: Ultra X-Connect 500W
Memory: 1 x 1GB Ultra 3200 RAM, 1 x 256 Corsair XMS 3200 RAM
HD: WD 160GB Caviar SE SATA
Video Card: XFX 6800GT
Optical: Plextor DVD+RW
I was copying files from my external hard drive onto my desktop hard drive, as per usual. I stepped out for a second, and heard a weird sound. I came back a few minutes later and found that my computer was off. I tried turning it on again, only to find that it remained off. I checked my external hard drive on another computer, and everything was still in working order.
I figured that my PSU had fried, as research into that model had found numerous complaints. I acquired another PSU and installed it into my setup, only to find that it too didn't work. At this point, I figure my motherboard is officially fried, and now I'm crossing my fingers that everything else (including the processor, memory, and HD) are still okay.
I suppose my question is, what could have caused this mess? I mean, my computer was hooked up to a surge protector, and no outside sources seemed to have caused this mess (i.e. no brownout, blackout or lightning). Furthermore, I've transferred tons of data using that specific external HD on multiple computers, without a hint of problem.
It's just.. ugh... so frustrating to have that feeling in my stomach that I might have to entirely replace a computer I just built a little over a year ago!!!
Witchfire
226
Have you tested any of the seperate components on another rig? How well the HDD has performed in other settings really doesn't have much to do with your current issue. A bad HDD wouldn't keep it from POSTing, nor of at least attempting to POST.
jteow
16
Well I checked my external HDD in other situations, just to make sure it didn't get fried during that whole ordeal.
As for the other parts, I checked my video card, memory, and hard drive on my friends computer, and everything worked.
I also tested the PSU on another computer, and it worked.
So right now, the only untested components are the processor and the motherboard.
