SERIOUS DVD PROBLEM??
OneOfTheseDays
7,052
ON every single software dvd decoder that i have tried i get this thin band on the right hand side of the screen that runs vertically from the top to the bottom. It is very anoying and i cant get rid of it. What is causing this. I have a geforce 2 gts, 6.27 drivers, sb live plat, pioneer 16 x dvd drive?????
OneOfTheseDays
7,052
yep, however, only on movies that are displayed in the proper aspect ratio. Movies that are supposed to fit the entire screen 4:3 movies dont display this problem. It only happens on movies that aren't supposed to fit the 4:3 screen.
steelthorn
252
You should have got a voodoo 5500 instead. The geforce 2 is plagued with problems like this.
