Series Help
mageslayer
624
1, 4, 10, 19, 31, ...
I need to write a formula to generate the nth term.
I believe it is a geometric sequence, however, I cannot make a formula.
Gibsons
12,530
35
X = 1
then a loop with something sort of kinda like
X = X + n
n=n+3
dunno if you want some sort of algorithm, but it shouldn't be too hard, just add 3 more each time. Next number should be 46...
mageslayer
624
I can see the pattern and find the following numbers, but I cannot make a formula for the nth term in the sequence.
CycloWizard
12,348
Originally posted by: mageslayer
that doesn't seem to work for the first term
y_1=y_0+3(0)
=0 ???
The entire thing is just the successive terms of the summation y=1+sum_n=1^i{3n}. What I gave previously was the recursive relationship that occurs within the sum. I didn't think I'd have to do ALL of your homework for you. :roll:
Rasico
10
The answer I believe is:
3 * (n)(n-1)/2 + 1
This is assuming the answer is 1 for n = 1.
Everyone pointed out the obvious: f(1) = 1
then f(n) = f(n-1) + 3*n.
So lets look for a pattern:
like f(f)
f(3) = f(2) + 3 * 3
= f(1) + 3*2 + 3*3
If we generlize this with n we get
f(n) = f(n-1) + 3n = f(n-2) + 3(n-1) + 3*(n-2) which would be the sum of all numbers from n to n-1 x 3 + 1.
The sum of all numbers from 1 to n-1 is n*(n-1)/2. Hope that made sense.
