UltraATA has a max STR (sustained transfer rate) of 133MB/s while SATA has a max STR of 150MB/s. Not like there are any harddrives out there that even come close to these transfer rates anyway. Serial ATA is a newer design since Ultra ATA is based on the "old" parallel IDE design and hence is more future-proof and has more capabilities such as NCQ, TCQ.
But most people like SATA mainly for the thinner cables which help improve airflow in the case itself.
