Originally posted by: MonkeyDriveExpress
They won't change to SATA as long as we continue buying $15 AR CD-RW drives. If there's no demand, they won't be made. They know people are more likely to buy a $15 PATA optical over a $50+ SATA model.
EDIT:That said, SATA opticals can't come soon enough. These PATA cables just have to go...
you know you can just buy rounded cables for 50 cents, right?
There's no point as far as peformance is concerned but in the future, there's probably gonna be MB without any PATA connectors at all and then SATA optical will be a necessity. This will happen sooner than many think I bet because SATA has a lower MB footprint which means lower costs (albeit only a very little bit lower)There's no point. Even hard drives don't push the transfer limits of PATA. So a CD drive certainly does not.
I don't want to buy el-cheapo cables, especially when they can cause errors and burn up my blank discs. Yes I know CD-Rs are cheap, but it still sucks to have a CD become useless, then have to re-burn it and hope that one works.
Originally posted by: Nebor
As of now, sata adapters don't work on CD drives... for whatever reason.
Funny, I've got a PATA to SATA adaptor that says it works fine on CDROMS and MO drives. I'll try it wednesday.
