Serial ATA hot swap
jjlsevil
200
Was looking for clarification on this technology. As far as I understand, it allows a user to connect and disconnect serial ata devices while the pc is up and running. Would this also allow connection and disconnection just buy removing all power? or does there have to be a constant supply of power when the serial ata cable is removed? The reason I'm asking is because i would like to add switches on the exterior of my case to allow powering on and off of specific devices when they're not in use. Furthermore, would a serial ata adapter allow theses functions (if I wasn't completely wrong above)?
Markfw
May 16, 2002
27,429
16,298
Serial ATA hot swapping is not supported on PC motherboards yet (AFAIK) My motherboard specifically says NO, and it is one of the latest. I have not read anywhere that its out yet.
Sheriff
1,182
Nor is it supported by Windows as of yet
