Septic Tank
tyler811
5,385
Mine is a 750 gallon tank with a field. We had it pumped 6 years ago when we bought the house. Is it time again to have it cleaned?
DeadByDawn
2,349
How many people in your house?
If 3 or more, I'd say get 'er done after 6 years. I think I paid about $150 to get mine pumped last year.
lxskllr
60,103
10,567
I'd do it every 2 years whether it "needs it" or not. Letting it get too full isn't good for the system, and it could end up being a big expense in the future.
Bryophyte
13,430
13
Typically, every 3-5 years. Six years and you're risking a plugged drainfield. That gets damned expensive. I get ours pumped every four years. It's easy to remember when to do it; I time it to correspond with presidential elections. :laugh: I like the symbolism.
OCGuy
27,224
37
I pump my SO's septic tank about twice a year. She has to be really f-in drunk.
waggy
68,143
10
not true.
it really depends on the size of the tank and number of people in the house.
http://www.inspect-ny.com/septic/tankpump.htm has a good guide.
tyler811
5,385
Well looks like I made it in the nick of time. I opened it up because I have an appointment tomorrow at 11 am. Took about 20 minutes to dig up and lift off lid. Almost all the to the top.
tyler811
5,385
Ohh almost forgot it will cost $125 to have it pumped. I called three different places and they were in price $150 $195 and $125 all with the access undug and opened. The one for $195 also they back flush none of the others said they did that but then I did not ask. I do not even know what it means.
Bryophyte
13,430
13
not true.
Interesting. Guess that's just the timeframe for our tank. Nevertheless, he said he has a 750 gallon tank, and said "we", meaning he lives with someone, so he's looking at 4.2 years between pumping, best case scenario, according to that chart.
olds
50,124
779
I believe they are designed to fill almost to the top before it goes into the leech field.
tyler811
5,385
not true.
3 people and needless to say we are ahum "behind" by 2.5 years.
tyler811
5,385
Yes gathering from what I have read in the article that was posted, I should be good. There is a picture of one filled almost to the top also and the author of the article said it was good.
boomerang
18,883
641
Yes, and then the leach field does it's job and allows the liquid waste to percolate down into the soil. A septic tank should never need to be pumped if the system is working as it was designed to do.
The solid waste breaks down into a liquid helped my microbial action. When the liquid level in the tank gets high enough, the liquid flows out to the leach field. They are designed to be maintenance free.
You should never have to pump a septic tank unless you have problems with the leach field or the piping to the leach field.
Bryophyte
13,430
13
Um, no. That is absolutely false. There will always be solids that settle in the tank. Even a healthy tank (with ideal bacterial conditions) will accumulate solids that cannot be further broken down and will need to be pumped out periodically to avoid having those solids (and more importantly, fresh, undigested solids) escape the tank and clog the drainfield.
ElFenix
102,402
8,574
i'll bet that smells fantastic
Insomniator
6,294
171
I don't understand septic tanks... your poop sits in them for years and they don't corrode or smell or anything?
Modelworks
16,240
7
The last time we had ours done the guy said that laundry detergent and bleach are a couple items that can hurt a tank by killing the helpful bacteria. Also grease can clog lines . He recommended the ridx stuff to boost the bacteria that might be killed off by heavy washing. Also recommended we get a grease trap.
Modelworks
16,240
7
http://en.wikipedia.org/wiki/Anaerobic_digestion
anaerobic digestion is a series of processes in which microorganisms break down biodegradable material in the absence of oxygen. It is widely used to treat wastewater sludges and organic waste because it provides volume and mass reduction of the input material.[1] As part of an integrated waste management system, anaerobic digestion reduces the emission of landfill gas into the atmosphere. Anaerobic digestion is a renewable energy source because the process produces a methane and carbon dioxide rich biogas suitable for energy production helping replace fossil fuels. Also, the nutrient-rich solids left after digestion can be used as fertiliser.
