Send and receive text messages without a cell phone?
Carson Dyle
8,173
524
Is there some way that you can both send and _receive_ text messages from a computer _without_ a cell phone? I've seen some software and services that will let you tie into a mobile account, but nothing that works without one.
Carson Dyle
8,173
524
I looked at Google Voice and it appears to want to be tied to a phone.
"Before choosing a Google Voice number, please add a forwarding phone that will ring when that number is called. You can add more forwarding phones later."
lxskllr
60,151
10,613
Dunno how they do it now, but back when I used it, I had a prepaid number I barely maintained. Sometimes it worked, sometimes it didn't, but GoogleVoice always worked.
What exactly do you want to do? Something like im would be easier and more secure, but of course your partner would have to use it also.
Carson Dyle
8,173
524
I want to text an online merchant to receive a coupon code, which will be texted back to me. It appears to be the only way to get the code. My cell phone is on the blink right now for some reason ("no service"), so I can't receive a text, nor can I activate the Google Voice account, since it wants to be tied to a phone and needs to dial the number for verification.
lxskllr
60,151
10,613
Check this out...
http://www.sendsmsnow.com/
Found via this search(may be others that will work if the above doesn't)
https://duckduckgo.com/?q=send+receive+sms+online
Dari
17,133
38
Yeah, you can add the forwarding number. But all you have to do is give out your Google Voice (GV) number. You can set everything up in the Google Voice settings so that your real phone number never gets any text or phone calls from your GV number. Google will check every year or so to make sure you have that forwarding number but they really don't care.
Soapy Bones
397
Google voice does what you want and if that merchant gets annoying you can easily block them. I'm moving almost all of that activity to google voice
Rakehellion
12,181
35
Get a friend to do it for you.
