"Self-Extractor corrupt"...Need help!
MiracleMax
11
I'm running Windows 2000 and the other day I started getting an error message right at startup. The message occures right after Windows loads the desktop. The message states, "Self-Extractor corrupt - probably do to bad hard disk or file."
Here's what I've done so far...
First, I thought it was associated with Winzip so I uninstalled and reintalled the app...no luck
Second, I dumped my start up folder just to make sure nothing was loading at startup...no luck
Third, I did a little research and found this error is usually associated with a virus. Specifically, the Chernobyl and I-Worm.Gift viruses. However, Chernobyl is an old virus (1998) and cannot run in an NT/2000 platform, and there is nothing in the WINNT/System directory or the registry [HKey_Local Machine].
Fourth, just to make sure I updated my virus definitions and did a virus scan...no viruses found.
Fifth, ran a scandisk...no luck.
The only head-way I've made is when you log in as a different user you don't get the message. So it only happens with one specific user account.
Any advice on how to get rid of this message? Thanx!
absentminded
36
Hey Miracle - this is related to the Bad Trans Virus from what i recall and that virus came around mid last year. Might give a look into this.
MiracleMax
11
Thanks for the help. I looked into Badtrans and there is a tool to search and clean it off systems. I'll let you know what happens.
