Selecting Strings and Converting to Dates with Oracle
Saint Nick
17,722
Code:
select time_stamp
from tidalard;
Returns a string in the following format. This is not a date type.
1998-09-15-17.31.27.001000
I modified it so it takes only the date using the below query.
Code:
select replace(substr(time_stamp, 0, 10), '-', '/') as ts_date
from tidalard;
Unsurprisingly returns
1998/09/15
Now, I've tried various combinations of to_date() and to_char() to convert this to a date. My desired output is:
09/15/1998
I'm not sure what else to do, if there is a way...
MrChad
13,507
Code:
select
    to_char(
        to_date(
            replace(substr(time_stamp, 0, 10), '-', '/'),
            'YYYY/MM/DD'),
        'MM/DD/YYYY')
from tidalard;
Saint Nick
17,722
Huh, I swear I tried that and it didn't work, but it did this time...thanks to both of you!
Seero
1,456
SELECT TO_CHAR (TO_TIMESTAMP (time_stamp, 'YYYY-MM-DD-HH24.MI.SS.FF9'), 'MM/DD/YYYY') FROM tidalard;
That way you don't lose the precision when you want to ditch the to_char.
ForumMaster
7,792
or... you could just do this:
select sysdate from dual;
this will return a date type without having to use to_char and all that.
systimestamp obviously returns a timestamp which is more accurate, but not a date type.
good luck.
the output will depend on your NLS_DATE_FORMAT which can be viewed by issuing the following query:
select * from nls_session_parameters where parameter = 'NLS_DATE_FORMAT';
if you want to change it, you can do like this:
alter session set nls_date_format = 'MM/DD/YYYY HH24:MI:SS';
the sysdate will then return the date in the desired output.
