I decided to order my mobo/cpu compo through Monarch Computer. I'm getting an Asus A8V Deluxe and Athlon 3000+ Winchester. I have the choice of 5 different CPU heatsinks/fan. I do plan to overclock a little so I do want the one that will cool the best but don't know which one that is (my guess it would be the $35 one since its the most expensive but wanted your opinions). Here are all the choices:
http://www.monarchcomputer.com...mp;Product_Code=130129
http://www.monarchcomputer.com...mp;Product_Code=130150
http://www.monarchcomputer.com...mp;Product_Code=130956
http://www.monarchcomputer.com...mp;Product_Code=130972
http://www.monarchcomputer.com...mp;Product_Code=130122
Oh and they also offer a $14 thermal grease option but if you read about the fan itself it sounds like they come with the thermal grease. Do you need to even check this if they already have it with the fan (would they just use that stuff?).
My next questions is with RAM. I've decided I want 1 gig of PC3200 but there is like 20 choices of that ranging from $200 to almost $300 for two 512 sticks. They seem to carry Corsair and OCZ but there are a lot of choices within those two brands that I can't tell the difference. Here is the link with the list: http://www.monarchcomputer.com...amp;Category_Code=AMDC
Thanks!
Thanks!
