seems low? 3850 3dmark05 (default settings, high quality in forceware)
xtknight
12,974
3DMark05 score: 3850
Does this seem a bit low? This is Computer 2 in my sig. I haven't optimized Windows XP much yet, but I still think this is a little low :(. My CPU is at 2440 MHz and my 6800NU PCIe is at 444/840 (effective). At times I was getting 1 or 2 fps, at the last two tests, which were running at 640x480 according to my LCD. Oh, and I'm using ForceWare 67.66 beta.
xtknight
12,974
Originally posted by: LTC8K6
Sounds good to me for that card.
Hmm, weird how an X800 Pro can get 6,000+ 3DMark05s. I didn't know my card was that bad...:disgust:
LTC8K6
28,520
1,576
Way higher core and memory clocks than stock is the answer. A stock X800pro wouldn't get anywhere near 6K. Stock is what, 475/900? Some of those guys had 600+/1200+ clocks.
You could also try different drivers. You'd be surprised how much your score can change.
I wouldn't worry about 3Dmark05 anyway, I'd worry about how well it does in games.
xtknight
12,974
Oh, okay...thanks
fstime
4,382
It does seem a bit low, you should be in high 9K-10Kish. Install your motherboard drivers? The 1-2 fps was the cpu tests, its normal, ummm try using the official 66.93 off nvidia's website, one thing I hate about my nvidia card is that there are so many damn drivers, hoppe that helps.
EDIT: What I stated above about the high 9K to 10K thing was on the regular AGP cards, I have no clue how the PCI-e cards perform.
xtknight
12,974
What? That's insane. Are you sure you're talking about 3Dmark05? An FX-55/SLI 6800 Ultra rig can barely top 10,000.
JBT
12,094
That score seems right to me. The 6000+ scores X800 Pro's are probably vmodded and Oced to hell as well as pipe modded. Why don't you try modding your NU to open up the extra 4 pipes and vertex shader to get more caparable scores with a 6800 GT atleast.?
boatillo
368
Yea well I scored a 2720 in 3dmark03!!!! Argh how do you think that makes me feel?
(Oh and...312 in '05)
