BonzaiDuck
First -- some tips or discoveries.
My old Trooper -- two-tone with Blue-Bronze-Pearl (main color) and Iron-Gray-Metallic (trim and lower doors) -- had a Hu-u-uge -- YUGE! -- square-yard's worth of gray and white paint oxidation on the roof -- the biggest single body panel. Of course -- nobody under 6'5" would really see it, but perfectionist OCD is a common trait -- which I have. The clear-coat was not yet peeling off.
I attempted to use rubbing compound on the splotch, but it didn't seem to change things much, and my efforts occurred before I purchased a Ryobi orbital buffer-polisher. My arms! My arms!
Then I discovered Oxide-Off. Forum-skinny shows a degree of skepticism from participants who haven't used it. You'd think there would be other alternatives springing up, for instance (and let me know of any). I bought a bottle six months ago to try against my specific problem. If I had before and after pictures, I'd post them, but the examples shown in the link are pretty accurate as to what one could expect.
The Oxide-Off people want to recommend it as a wax alternative, while confirming that regular wax can be used after the Oxide-Off application. I'd rather not count on Oxide-Off in its entirety -- it's too expensive at $25/6-oz-bottle. One bottle will treat two cars or one car twice. And I found that you can apply Maguiar's pre-wax finishing glaze between the Oxide-Off and wax. Apparently, Maguiar's "Hybrid Ceramic Wax" can also be used, with no problems or after-effects. Now, I often go to the garage to comb my hair and shave.
The first time I applied Oxide-Off, I watched it over six months. At some point, I soaped off the wax, or so I thought. No change.
So I'm planning a regular regimen. Every six months, remove the wax AND the Oxide-Off, re-apply both in the proper sequence, buff, shine and wait another six months.
Rather than use rubbing compound or polishing compound (with abrasives) to remove the wax and Oxide-Off at each successive cycle, I'd rather apply some mild chemical wax remover.
Somewhere, I had indications that you can remove wax with soap and water. But on my six-month cycle, I cannot leave any residue of either product.
Looking up "automotive wax remover" on Amazon, I find many products, which all show on the label or item-web-page promotion "great preparation for new paint". But I don't want to use something that will alter the paint in any way. Oxide-Off's oxidation reversal seems to be a permanent restoration of the original paint, and the product can then be removed, or you can leave on the thin film -- as I said, promoted as a wax alternative.
Tell me what you know. Soap and water? Wax and grease remover? Recommendations?
