Help!!!
I just tried to install a second device (DVD Writer) as a slave device on my secondary IDE chain. With one device on the chain everything works as it should, but when you add a second device the boot process halts at the Windows logo screen. I checked the event viewer and found the following:
Event Type: Error
Event Source: nvatabus
Event Category: None
Event ID: 4
Date: 1/20/2005
Time: 7:43:21 PM
User: N/A
Computer: RALPH
Description:
Device slot returned an invalid status value. See data for detailed information.
Data:
0000: 1b 00 0c 00 01 00 66 00 ......f.
0008: 00 00 00 00 04 00 de c0 ......ÞÀ
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
0028: 01 00 01 00 e5 00 de 10 ....å.Þ.
0030: ff 00 00 00 ÿ...
PC is using a DFI LanParty UT 250b NF3 with a AMD 64 processor (2800), Xtasy 9600XT, 1 gb ram, Windows XP Home SP2, and 450w power supply. If there is only one device on the secondary, it boots normally but with two devices (I've tried both a DVD rom, a CD writer and the new DVD writer)...boot failure. I've replaced the cables, checked the master/slave pin settings and tried different positions on the cable all with the same results. The primary IDE is fine and has two standard IDE hard drives attached and working.
Any and all help gratefully accepted!!!
Event Type: Error
Event ID: 4
Date: 1/20/2005
Time: 7:43:21 PM
User: N/A
Computer: RALPH
Description:
Data:
