billandopus
My secondary IDE Bus Controller has a Plex 8/4/32 hooked up as Master.
However, the Plex is not working at all.
Somehow the Plex is recognized during bootup but when you hit "System Properties/Device Manager" the Plex isn't recognized there. Primary IDE Bus Controller is recognized and is "working properly" Secondary IDE Bus Controller has a big yellow exclamation mark and says:
Device Status: This device is either not present, not working properly, or does not have all the drivers installed (code 10) Try upgrading the drivers for the device.
I've tried upgrading the drivers but it wouldn't let me. Said that the best drivers are already installed.
I went to Start/Settings/Control Panel/Add New Hardware and it found the Plex as:
"Secondary IDE Controller" not as the Plex. Hmmmnnnnn.
So, i'm confused. WTF is going on?
The plex is obviously recognized, it's telling me that it's installed but it's not functioning properly.
I've pulled apart the case and made sure that all IDE connnectors were properly contacted and the whole bit but the same thing happens.
What are my best bets? Anyone have any suggestions?
I really need some help and I appreciate any pointers or suggestions.
Thanks
AMD k6-3 400
Asus P5A mobo
Quantum HDD Primary Master
Toshiba cdrom Primary Slave
Plextor cdr/w Secondary Master
Thanks
AMD k6-3 400
Asus P5A mobo
