- Check the cable is a 80 pin one, a 40 pin cable will only work at UDMA 2.
- While youre doing the above, put the harddisk as master and cdrom as slave. As a general rule, always put fastest drive first on a channel.
- If the above doesnt show it sorted, go to Device Manager > IDE/ATAPI Devices > hghlight Secondary IDE Channel and press Delete. Dont worry it will reappear on reboot, and select the fastest speeds it detects possible.
If after a while it resets to UDMA 2 again, its probably because it's detecting too many errors, though only recall seeing this happening on CD drives, so possibly this doesnt happen for harddrives? Anyway, in this case try a new cable, and route it away from anything that might give interference. If it goes to UDMA 2 immediately, then 😕
