Second hand LCD monitor buying checklist.
sumedik
Well if I buy a second hand LG LCD monitor from someone not personally known to me, what should be the things that I should be looking at before deciding whether to go ahead with the deal or not?
Here are a few things that I could could come up with:
1. The original bill and warranty card(seller claims it is under warranty period). Is there any way to verify that these docs are genuine?
2. Physically checking to see that the stickers on the monitor which void the warranty if removed are intact and also checking the physical condition of the unit for scratches etc including the condition of the connecting wires and connectors.
3. Turning the monitor on and checking for dead pixels(are these seen as black spots on the display?) and leaving it on for an hour to see if there is any fading of display colors or vibration.
4. Checking to see if the monitor is unusually hot after running for 1 hour.
Apart from these, is there something else to be considered? Is there any software that can be used to test the condition of the display etc?
Please share your knowledge.
why would you but a used monitor when you can buy a brand new 23 or 24 inch 1920x1080 monitor for under 200 bucks? if they don't need something that large then a brand new 19 inch can be had for around 100-120 bucks.
I'd personally just grab a new one like toyota says unless you really is pinching penny. lcds are not really that expensive nowadays and one will last you forever and ever.
Well I am in India and LCD monitors, specially the big ones are still in the high price range. Also I would go for the second hand one only if I get a good bargain price, otherwise not.
