secc2 and PASSIVE cooling...
Kartajan
This is my problem. dual p3-600. fans are too loud. I figure if there is any kind of passive cooling for SECC2, that would do fine. Not planning on o/c. Sources anybody?
You might post a WTB thread in FS/Trade for a couple Alpha P3125's, or as I mentioned before, the Globalwin VOS32. The "rear" CPU would need a P3125 that's been shortened up, since there is typically not enough room between the two CPUs for an unmodified P3125.
Even with these top-notch heatsinks, the CPUs will run very, very hot without forced-air cooling. I still think you'd be best off using just one CPU for the purpose you stated previously.
