Originally posted by: Nocturnal
this warm
this warm
You must be kidding.... :roll:
This PSU is blowing a lot of warm air out the back. Is it supposed to be this warm? I don't remember it being this warm with my Antec TruePower. I do see the fan on the underside spinning.
The S12 and M12 are some of if not most efficient PSUs available, that means less heat per watt of output power hence the fan can run slower. Also Seaonic has one of the best active fan controllers in any PSU; if the load is low so is the heat; no need to spin the fan faster and make more noise then is necessary.Originally posted by: Zepper
Dittos Dave. I think lots of PSU makers run their fans too slow on purpose in favor of low noise over optimum performance of PSU so I've taken to manually controlling them.
.bh.
Originally posted by: corkyg
My M12 700W has a big fan on the bottom - it quietly draws air out of the case, and it "drifts out" out the back. There is nno rear fan. There is, however, an auxiliary fan in front which is thrmostatically controlled. It only turns on to push air out the back if it senses a high enough temperature within the PSU. Mine has never turned on, so silence is golden.
