- Jan 12, 2005
- 1,351
- 29
- 91
I have the Seasonic 750 M12 II modular PSU. One of the Video card connections has 2 6 plug connectors on it. It is an AMD 7870. Do I use the two on the one connector that has two or are you supposed to hook up the other modular one that has two on it and use one of those so you would be using 2 separate connectors? Does this make sense the way I worded it? Is anyone familiar with the Seasonic? Thanks.
