- Jan 17, 2001
- 2,528
- 10
- 81
I was looking for a good window air conditioner to but in my 2-year-old son's bedroom for the summer and found that Sears has a Kenmore 5300BTU on sale for $149 (reg. $209) until 5/17. This is Sears Item #02272056000(Mfr. Model #72056)and has a remote control, automatic temp control (thermostat) and an EER rating of 10.8. I bought a Kenmore model 71055 two years ago (similar unit - 5600BTU) and it was been working GREAT!
As a bonus - some states have an energy rebate program where the give you $$ if you trade in an older A/C unit and buy one that is Energy Star compliant (this one is @ 10.8 EER). I took advantage of this in NY state 2 years ago and got a $50 rebate for trading in an older unit that I bought at a yard sale for $35 two years earlier (bought the 71055 with an EER of 11.0).
Go to Sears.com and search for item #02272056000. This is available online and at B&M stores until 5/17.
The Specs:
General Warranty 1 year
Cooling Capacity 5,300 BTUs/hr.
Color:
Overall White gray
Cabinet White gray
Front White gray
Controls:
Control Type(s) Electronic
Status Indicator(s) LCD message window
Temperature Adjustment Precision Electronic Thermistor
Temperature Selection Dial with numbered settings
Dimensions:
Cabinet Depth 14-9/16 in.
Cabinet Height 12-9/32 in.
Cabinet Width 18-9/16 in.
Max. Wall Thickness 5-1/8 in.
Window Min./Max. 22 in. / 36 in.
Energy:
Energy Star Compliant Yes
Kilowatt Hrs. per Year 367.5
Energy Efficiency Rating 10.8 EER
Filtration:
Enhancements Removable air filter
Filter Type Permanent
Performance Features:
No. of Cooling Speeds 2
No. of Fan Only Speeds 2
Air Direction 4-way: adjustable horizontal and vertical louvers
Air Discharge Top
Dehumidification 36.0 Pts./24 Hrs.
Fan Type Turbo fan
Power & Ratings:
Amps (Cooling) 5.0
Cord Length 6 ft.
Plug Type Parallel blade
Rated Amps (Receptacle) 15
Volts, Ttl. Connected Load 115
Watts (Cooling) 480
Quality Features:
Compressor Type Rotary
Construction Condensate drain
Installation Aids L bracket
Safety Automatic reset
The Specs:
Color:
Overall White gray
Cabinet White gray
Front White gray
Controls:
Dimensions:
Energy:
Filtration:
Air Discharge Top
Fan Type Turbo fan
Power & Ratings:
Amps (Cooling) 5.0
Cord Length 6 ft.
Watts (Cooling) 480
Quality Features:
