Seagate STDSA10G-RK FreeAgent DockStar Network Adapter $19.99 + $5 Shipping @ Woot
Status
Not open for further replies.
Ah, there's a trick
You can use this as a home network server for windows without signing up with pogoplug or installing any software.
Plug your USB drive into your computer, format it (preferably with NTFS) and create a file on it named .ceid
Using notepad, or your favorite text editor, put these lines in the file
(replacing yoursharename with a name of your own choosing). Note the mode=rw
allows reading and writing.
servicename=yoursharename
xcode.metadata=never
xcode.thumbnail=never
xcode.stream=never
cifs.mode=rw
Plug the usb drive into the Dockstar, and you’re all set. The drive will be
available as
\\fadsMMMMMM\yoursharename (where MMMMMM are the last 6 letters and numbers
of the Dockstar’s mac address, which is on the label on the bottom).
Interesting product. So basically... if I'm understanding it correctly, it is an enclosure-less NAS that uses USB ports for the drives?
yup... seems like kind of a lightweight, no hurry kind of way to plug a couple drives into the network... i was going to grab one to see if it works good enuf to turn off my server pc that the family file shares / backs up docs to...
basically. the top is also shaped for their special drives, but it hink youc an plug other drives into it too with standard usb ports.
Status
