Seagate "power of one" HDD high failure rates?
futurefields
6,470
32
you can get 3tb of 7200rpm for a hundred on Amazon. Seems like high fail rates. Maybe they sell a ton of them and what you are seeing on Amazon reviews are the squeeky wheels.
anybody running these? for a stanard gaming pc
Feb 25, 2011
16,994
1,622
Meh. $100 is an average price for a 3TB HDD.
Seagate has higher failure rates than the industry average. If you're playing the odds, buy WD Black or a Toshiba/Hitachi.
That said, either of those could fail within a week. There are no guarantees, only warranties.
futurefields
6,470
32
$100 is not average for a 7200rpm 3tb
where do you see WD Black for $100 or Toshiba/Hitachi
master_shake_
6,425
292
121
power of one my ass.
i've got 13 seagate 2tb "one platter per terabyte" drives ST2000DM001 to be exact.
one failed and i didn't feel like rma'ing it so i opened it.
3 platters.
so i checked online and compared to the other ones i have.
NONE are 1tb per platter disks.
im sticking with the toshiba 2tb's
Feb 25, 2011
16,994
1,622
Go to pcpartpicker and sort by $/GB - the 3TB HDDs are the lowest cost per GB, and there are a bunch of models in the $90-$110 range.
http://pcpartpicker.com/parts/internal-hard-drive/#sort=a6
Toshiba (which bought Hitachi's drive manufacturing):
http://pcpartpicker.com/part/toshiba-internal-hard-drive-dt01aca300
Doesn't show there, but it's $99.99 at Microcenter, as well.
WD Blacks are overpriced because they're "enthusiast class." I wouldn't pick one over a Toshiba unless it were the same price. (They're faster, but the performance gains wouldn't matter in my NAS anyway.)
Feb 25, 2011
16,994
1,622
3 platters.
::Toshiba Fanboy Fistbump::
futurefields
6,470
32
3 platters.
you need 3tb to be guaranteed the 1tb platters
Data-Medics
131
www.data-medics.com
3 platters.
They were aiming for a 3Tb when they made yours, it's just that there weren't enough good sectors to make up 3Tb so they bumped it down to a 2Tb. It's pretty standard in hard drive manufacturing. That magnetic spray coating on the platters is never perfect so the drives go through a self-scan after being built to discover and block off bad areas of the platters.
Some make it as a 3Tb others get bumped down to a 2Tb some a 1.5 Tb.
As a rule of thumb avoid Seagate these days, especially anything with "DM" in the model number. Not only do those have high failure rates, but they are almost impossible for data recovery.
smitbret
3,382
17
I don't think there are any 2TB in circulation that aren't 1TB platters at this point. You can tell what they are by the size of the notch in the upper right-hand corner. If it covers almost the entire 90 degree curve, it's the 1TB platters.
http://technewspedia.com/the-confusing-2tb-seagate-barracuda-7200-14-st2000dm001/
I've got 4 that I have been using in my server for 18 months. They are quiet, cool and OMG they are fast.
Atreidin
464
27
86
Maybe it's just me but the terminology the writer in that link uses is really annoying. Calling platters "dishes" and "plates" makes one sound retarded.
futurefields
6,470
32
i spent a little more for a wd black instead
mostly because 5 year vs 1 year warranty on seagate
lopri
13,314
690
3 platters.
:biggrin:
XavierMace
4,307
450
I've got 8 STBD2000101's that have been running strong for a year and a half so far in my SAN.
