Does Seagate offer an advance replacement option (you give em your CC#, then they send you the replacement, then you use that box to send in the bad drive)?
Yes. They usually don't hassle me about it. I say I work IT and I know when a drive is broken and I need an advanced RMA for work to continue. They usually agree =]
