Seagate FreeAgent Desktop Drive 1TB USB 2.0 External Hard Drive - #ST31000FDB1E1-RK
Pardus
Seagate FreeAgent Desktop Drive 1TB USB 2.0 External Hard Drive - ST31000FDB1E1-RK
Price: $119.99. Free ship. Tax where applicable.
* Capacity: 1TB
* USB 2.0 & 1.1
* 32MB Buffer
* 7200RPM
* Capacity: 1TB
* 5 Year Warranty
* Vast capacity with a footprint no bigger than a stapler.
* Dimensions: 7.5"H x 6.4"W x 1.6"D, 2 lbs.
* Just plug it in and you're ready to go.
looks like the $130 one has firewire and esata support, other than that, I'm not sure what other differences there may be
Originally posted by: looker001
What is the difference between what you posted and this one
Seagate FreeAgent Pro Data Mover 1TB 32MB Buffer eSATA, FIREWIRE 400 & USB 2.0 External Hard Drive - ST310005FPB1E3-RK.
SEAGATE:
FRYS.com #: 5697121
Capacity: 1TB
eSATA, Firewire 400 & USB 2.0
32MB Buffer
7200RPM
5 Year Warranty
$129($10 difference) and it also has firewire.
http://shop2.frys.com/product/...sr:SEARCH:MAIN_RSLT_PG
FreeAgent Desktop Datasheet #ST31000FDB1E1-RK * FreeAgent Pro Datasheet #ST310005FPB1E3-RK
eSATA & USB connectors are in the same base insert that must be swapped out in order to use 1394a Firewire 400.
The enclosure is heavy & solid with a small wall wart (similar to cellphone power adapter) instead of the brick-like laptop power adapter type.
