SE440BX-2 and Celemine CPU not compatible?
Gillbot
28,830
17
i got a SE440BX-2 and wanted to upgrade my PII 350, i thought Celemins on a Slotket would be great. Set the FSB and Voltage Jumper on the slotket and go!! NOPE, won't boot at all. is the CII and SE440BX-2 incompatible?
Gillbot
28,830
17
i'll have to try some other settings to see what happens. but it acts like it doesn't even have power when i install the CII cpu into the mobo and try to boot.
Gillbot
28,830
17
yes i have tried the latest bios but it will not update. i run the flasher prog and it says bios updated, but upon reboot it has the same bios # as before.
