SD500 owners, what camera case are you using?
cheapgoose
hey guys, just wondering what some of you Canon SD500 owners are using to protect your camera. Mine's got some scratches on the casing. I went to bestbuy and got one of those hard leather delux case for my camera. I know it fits my SD300 for sure, but it won't fit the SD500. I have one of those thick acrylic cover for the lcd screen.
anyone else have the same problem? I would really like a new case.
Originally posted by: ironcrotch
my camera is caseless, i just slide it into my back pocket whenever i need it.
Me too, but I also don't buy expensive cameras (currently using the SD200) so I don't care if it got scratches
wow no cant have scratches in a $450 (retail) camera. I use the PSC-50 leather case from canon. It works very well and has a little hole on the top for the wrist strap to go through so you can carry it easily. (even with the case it fits into pockets decently)
I'm using the PSC-50 right now too. It's a little big for the SD500 - which I thought would be the case, since I use the same case for my S400 (which is a bit thicker). I'm looking for something a little smaller at the moment (was looking at the PSC-90 but apparently, it's too small for the SD550 (which is essentially the same size as the SD500)
Apparently, there's a Coach branded case for the S500 but I personally thinks it looks like crap.
i had the psc-50, but didn't like the quality. i ended up getting a lowepro edit 10 i think. fits very well and soft inner case.
