Scythe Ninja running passively for a 3800+ X2?
Smartazz
6,128
If I ran this 3800+ @ 2GHZ Windsor passively, would that work well enough to keep the temps to a safe level? I think it's 89watts. Thanks.
Smartazz
6,128
Originally posted by: corsa
...maybe @stock, but no way if OC'd......whats wrong with a silent fan?
I've never used the Ninja so I have no idea how quiet the fan is. The Scythe Mine is another possibility, which I heard is better with active cooling than the Scythe Ninja.
BlueWeasel
15,944
475
At stock speeds and decent case cooling, I think it would work.
I built a system for a friend of mine with hearing problems consisting of a X2 4200+ running at stock speeds and the Ninja without a fan. The load temperatures maxed out around 58-59C while dualing priming, and while just a little high, the system was perfectly stable. This was in a P150 case with a 92mm intake fan, a 120mm low speed exhaust, and the 120mm fan in the PSU.
The Scythe fan is extremely quiet, and in the end, we installed it on the Ninja.
