Scythe Kaze Master - No Display
zero koopa
So I have a Kaze Master and it is not displaying the RPM or Temp yet Im able to adjust the speed of the fans.
3 Scythe Slipstream 1900 rpm fans.
Hooked up using the provided extension cable
I swear it was working yesterday.
aigomorla
21,067
3,575
Originally posted by: zero koopa
So I have a Kaze Master and it is not displayig the RPM or Temp yet Im able to adjust the speed of the fans.
Hooked up using the provided extention cable
mmmm as i said i have no idea.
Try connecting another fan to it? something different and see if that helps/ Also connect a temp probe to it and see if something displays.
Lastly, if you have another psu try it out there, and if all comes to worse, i think you might need to RMA. Where did you buy it from?
zero koopa
all temps gages are attached to the unit but not attached inside the case. I don't want to send it back cuz all the fans are zip tied and nice and neat. You'll have to excuse me *BANG HEAD ON DESK REPEATEDLY*
Also the sound jumper is on yet no sound when I turn it all the way down. Bought it from Heatsink Factory
aigomorla
21,067
3,575
rma time :X
