- Oct 7, 2005
- 4,142
- 0
- 0
Both of the jacks where 3k RPM Ultra Kazes connect are messed up.
At first everything worked as it should but now they can either be 100% or off!
Im going to RMA it but kind of sad that the KAZE MASTER can't handle the Ultra KAZE fans...
Anyone know of a strong fan controller?
UPDATE:
Ok the Rheobus came in the mail today. Works great so far. 2 gripes: comes with only 2 real 3 pin extensions. The others are molex to 3 pin and Y type to connect it to the mobo as well as the fan controller (Couldn't get this to work correctly).
Another one is that the lights can't be tuned down. As the RPM changes so does the light but it starts off bright enough!
The build quality is definitely better than the Scythe Kaze Master. It has big heatsinks.
UPDATE:
