- Oct 26, 2000
- 433
- 0
- 0
I'm putting together a Q6600 system.
I'm using the ASUS P5K-E LGA 775 Intel P35 Link and the Antec P182 Gun Metal Black Case Link.
I have seen good reviews about the Scythe Infinity Link in regards to cooling and quietness. I know it's really big and that's fine as long as doesn't cause a problem with my motherboard (I've already seen lots of people with the Antec P182 case and it looks like it fits fine). Based on the motherboard pictures it looks like I should have plenty of clearance but I wondered if someone had experience with this motherboard and the Scythe Infinity to verify.
Also, my biggest concern is with the weight of this cooler. It's listed at 960g. Since it will be mounted at the standard 90 degree angle in the P182 I'm concerned that it will cause my motherboard to bow and possibly break. Has anyone done anything about this or has this caused a problem with anyone else?
Btw, I have noticed that Scythe has a "Universal Retention Kit". They have a "Buy Now" feature on their website but all the websites that they recommend getting it from (including NewEgg-my preferred site) do not have it. Do you know of any other places that might have it or can you recommend another "Universal Retention Kit" that would work.
