Recently been doing benches on my AMI/LSI Logic MegaRAID controller and looks like there is a HUGE performance gap. Basically using two 36GB 10K IBM ultrastar drives...
Tiger MPX (32bit/33MHz)
If you look at that bench (ATTO) there is a HUGE performance difference between writing (slow as hell) and reading (resonable). Since the card I have is only has provisions for 64bit/33MHz operation and the board only has 64/66 slots I can't take use of the 64 bit transfers the card offers. Even so, shouldn't write speeds at least be a lot more closer to the read marks?
Then I decided to go with the Tiger MP which had support for 64bit/33MHz slots.
Tiger MP (64bit/33MHz)
Big difference... However, on cached I/O performance on the MP seems to get around 150-200MB/s LESS compared to the Tiger MPX. I would assume that cached I/O performance would be better as there is more bandwidth available. Any thoughts?
Also, other than buying a 64bit/66MHz RAID controller, any other ways to bump up performance when using 32bit/33MHz? Would really like to get those write scores up.
