SCSI probs..please help
RadicalMann
7
I have a VERY curious problem.
I have a SCSI card that I've tried on several IRQ's, always the same thing. If I have all my SCSI devices connected then for some reason my SCSI CDR gets "polled" every now and then.
The net result is a momentary 'lockup' of Windows and whatever I am doing regardless of work or game. My other SCSI devices seem to be working quite normally.
If I unplug the CDR the problem disappears and I can get on 'normally.....BUT.....I need the CDR.
Questions:
1-What could be causing this???
2-Is there a setting or command I can use so the CDR does not get polled?
Curious fact:
I had the SCSI device on IRQ9. Windows said it was working normally, no conflicts but it did share the IRQ with the "VIA PCI to USB controller". When I set my SCSI card to IRQ 4 in the motherboard's bios the USB controller moved with it too....DOH!
Why, anyone?
I used all the default bundled Win_ME drivers with the exception of those listed below.
Could the latest Via 4-in one drivers solve this?
I have read that the Microsoft DMA controller is faster so I stuck with the default drivers..and my HD is VERY quick according to Si-Soft Sandra.
I have:
Windows_ME / clean install /
ASUS 3PV4X, 1005 BIOS
128MB PC133 / Hyundai
PIII700 @933 / 1.65v (my problem is there even if I don't overclock)
Maxtor 7200rpm 30gig / 1st IDE channel / DMA enabled.
AOpen 32x CDROM / 2nd IDE channel / DMA enabled.
Diamond TNT2 /latest Nvidia Detonator drivers
Diamond MX300 vortex2 sound card / latest ref. drivers.
3Com EtherLink XL PCI Combo 10bT network card / Win_ME drivers.
ASUS SC200 SCSI PCI controler / Win_ME drivers (Symbios 53C810 device)
SCSI devices:
Matshita SCSI CDR (CW-7502)
SyQuest EZ230 external drive.
UMAX 600S scanner.:confused:
mastertech01
Moderator Emeritus Elite Member
Nov 13, 1999
11,875
282
The slot you have selected shares with USB.. you will have to move it to another slot if you dont want that..must be a bus mastering slot. Make sure all devices are not terminated but the last drive on the cable. If the card has a boot bios and you are using a SCSI Hdd check the setting for all the drives. Try to deselect auto insert notification if the problem persists..and check back here if you continue having problems.
