SCSI Pin Interface Difference
SoldatRU
21
Can someone tell me what's the difference between a 80 pin interface Seagate Cheetah X15 and a 68 pin interface one? Is there a difference in performance?
bockie
100
First of all, as Lord Evermore has subtly said, www.google.com is your friend.
The links provided give valuable info. Basically the difference between a 68 pin & 80 pin connection is that the 80 pin connection is meant for use with Hot Swap SCSI Backplanes that are typically on found in high end servers and disk arrays. A 68 pin drive has a separate power header (the four pin molex connector you see in a pc case) whereas the 80 pin receives it's power through the cable/connector.
I would like to add that you can run a LVD (low voltage differential) drive either a LVD or SE (single ended) scsi card with no problems.
Check out the following links for more SCSI information, specifically regarding LVD & SE interoperability...
http://scsifaq.paralan.com/index.html
http://www.storagesearch.com/lvdart.html
