- Jan 22, 2006
- 1,294
- 0
- 0
Hello. I'm not an infant with SCSI, but I'm far from any server tech.
I'm using a DPT PM1564U3 adapter, (it's a U160 adapter), and I have 4 SCSI drives.
One is an 80-pin Seagate U320, the other 3 are 68-pin U160's.
The card finds the U320 inside my hot swap bay just fine, (using ID3 just because that's what it was set to last time I used it), but I cannot get any of the U160's to be found either in the card's BIOS or on the boot scan where it looks for 'devices'.
The drives are all used, and they all came out of working servers.
I've tried each drive individualy, tried setting IDs from 0 to 6, (the card is 7), and tried all of them, 2 of them, all set to 0, set to 0, 1, 2, etc...nothing is working.
I'm using the same cable for all these configs, and it's got an active terminator on the end, nearest the first (or last?) device, being the HDD. The opposite end is in the card. Also, the cable does not have LVD written on it, but the terminator does,(should it say LVD if it's LVD compliant?).
The cable is: Amohenol G802002
Terminator: G5925733H
The 36Gb model:
Seagate Cheetah ST336607LC
The models of the 18Gb:
2x Seagate ST318404LW Cheetahs
1x IBM Ultrastar DDYS-T18350
I can hear all the drives spin up, LEDs indicate they're powered.
All the drives have "SCSI LVD/SE" on them.
Anyone can help me figure out why they're not being found?
The 36Gb model:
