Hopefully someone can help me here.
Ok I had an old scsi ricoh 6200s burner (it can't burn anymore, failed 4 consecutive burns and since I don't want to make more coasters, I figure its dead. also it made funny noises when nearing the end of a burn before it failed) it used to be scsi id 0 i believe and on the end of the scsi cable. The ricoh burner also had its own active termination so I didnt need to worry about termination.
also on the cable is a toshiba xm6201 scsi drive it was scsi id 1.
anyways I removed the old ricoh and set the toshiba drive to scsi id 0 by removing the black thingy(what is this called anyway?) that covers the 2 prongs for id1. also I set the termination on the 5th column using the black thingy(am I supposed to do this?, I tried w/o it and I still couldn't access any cds). The problem is when I boot to windows it sees the cd drive (I look in the system devices and the toshiba is recognized as a xm6201ta, and its the E drive), but if I insert a cd, it doesnt see it. The drive acts as if no cd was inserted and the cd unaccessible. So am I terminating it wrong here? do I need to buy some terminating plug instead of using that 5th column setting?
